cheers for that, no way i was buying a new one for £123.... just wanted to make sure i got the right one:thumbsup.
Gotta love parts systems, havn't come across one yet where the parts are listend in the obvious places..
Super Moderator
nope you just remove the main strip they are in, the main strip hooks onto the corner peices (where the gaps are) its just clipped in try and pop the corners out a bit with a table knife or thin flat screwdriver and detach them from the main strip, then run ya fingers top and bottom of the strip gently releasing it from the rear valance dont try just pulling it off yal crack it..
refitting you need to make sure the ends stay hooked onto the corner peices then side of ya hand go along popiing it back in this way you dont end up with unsightly gaps at the corners..
you can pop the corner peices out slightly or remove them it helps the proccess..
its actually easier than it sounds..
i did a how to on another forum but i left and lost it ive only got a bit of a piccy left of it..
