So, after the rear of my car fell off the jack… (don't ask!). The suspension was noticeably wonky - one wheelarch was a couple inches lower than the other. I replaced the springs, and it seems better but it's still not even - one side is still an inch or so higher than the other and I can hear a knocking coming from it.
My next idea was to replace the shocks (and mounts?), but is there anything else I might be missing…? Will also check the subframe mounts to check I've not done something really bad…
I had one lowering spring on passenger side on mine when I bought it!
Are you certain you've put the same size springs on :hihi
Seriously though, anti roll bar maybe?
