Opened the door yesterday morning as per usual.
Went to close it, it bounced, so handle up, forced it to close as i needed to get off to work.
Only problem is, ive tried to get in this morning & it now wont open from the inside, or the outside.
No resistance on either handle like usual.
Im guessing a cable has come off?
Door is closed, so how the hell am i going to pull the door card off?!
HELP.
Wow that sounds like a bit of a pickle :D
Tricky one this, but if you can get the 3 Torx 20 screws off of the arm rest, and then 1 behind the Airbag badge and 1 behind the door handle, you might be able to pry off the top of the door trim.
You could possible reach down then to tug on the cable to open the door ?
