Was making a 40 mile round trip, about 10 miles in, handbrake warning light came on although handbrake was off, and there was no difference in speed or braking. Traction control light came on soon after.
At about 30 miles in, brakes suddenly go really soft. First 2/3 of travel cause no braking activity at all, and the final bit works but not to the same extent as normal.
Pumping the brake when the car is off brings it back to normal give, but as soon as the car is turned on, the brake goes soft again
Does anyone know what this could be?
Vendor
You need to get this checked asap
Start with checking the brake fluid level if it's very low check for leaks
It may have air in the system if the brake fluid has not been changed for a long time
Water in the brake fluid will turn to a gas if heated and give you a soft pedal or go to the floor
Or seals in the braking system are worn
Check your brake hoses and metal brake lines for leaks
If the pedal is very soft or goes to the floor don't not drive the car any more
If you can't find any problems get it to someone who can and leave it with them till it's all fixed
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW,Alpina Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal of its guts or replacement
40% of my work is repairing the problems that are caused by other tuners Remaps
0208 561 1818
07831 103030
Hayes
UB3 1BB
