Hi guys, this is a noob question, hopefully somebody can point me in the right direction.
I have a 325i coupe tiptronic gearbox 2002.
Iv been having some problems latley and took it to have a diagnostic check.
The following problem have been highlighted.
- main relay switching delay (DME)
- fuel trim bank 2, permissible range exceeded
- misfire, cylinder 2
- data comprasion incorrect (SSG transmission)
- can bus malfunction DME-SMG
- also further investigation required, possible air leak.
How do i go about sorting these problem out, what could have caused them.
Any ideas on what the repair cost would.
can anybody help
the misfire could be a coil on it's way out, they are common for going, replaced a few myself, more so on the later m54 engines.
Do you have the actual code numbers?
