You are going to hate me for this post. According my travelling auto electrician (mine as he is the guy I always call for major wiring issues after meeting him at a dealers where he was working on a car some time ago), the largest amount of failures of any one component in the compact range requiring his attention is the rear wiper motor. He had done many in his time.
The water supply for the washer on the rear runs through the motor itself. It's a
[email protected] design. The fitments through the motor are prone to leakage, and with nowhere to go, the water stays in the motor.
Water and electric motors don't mix.
For those with a bit of mechanical ability, stripping the motor and greasing it, along with drilling a drain hole for any potential leak appear to be the advised options for avoiding the failure.
Ringing around scrap yards for spares prior to finding out this information showed a dearth of rear wiper motors on the second hand market. I am kind of thankful for that in as much as the replacement could well have the possibility of early failure.
I bought my current compact knowing the motor on mine wasn't working. The dealers I bought itfrom had to pay for the rectification. The 200 pound plus bill for the motor didn't cheer them up much as the deal had already been signed and sealed.
Unfortunately for them, the replacement motor didn't cure the fault. It tookan auto electrician (the same guy who fitted the replacement motor) another hour to find the wiring fault the motor had caused. It wasn't a fuse, he had to chase the wiring after identifying it to rectify the problem.
The motor itself (the original) had seized solid and whoever owned the car had done nothing about it. As a result, instead of blowing the fuse aswould be expected, the motor put its load on the wiring.
It didn't matter to me as the fault was cleared while I sat and watched, so I knew it had been repaired properly.
good luck on the repair, here's hoping it is just a fuse.
