Have been trying to remove my EGR valve to give a good clean up, however I am having some problems removing it from my car. I can undo the 4 10mm bolts, and the main hose on the front of the valve but I can not seem to release the pipe on the right hand side of the valve that appears to go into the exhaust.
It is held together with a jubilee clip, item #6 here:
http://www.realoem.com/bmw/showparts.do?model=AS72&mospid=47635&btnr=11_3334&hg=11&fg=50
The pipe seems to have a flange on both sides that overlap each other. Also, the jubilee clip seems to be welded?? to the pipe in question.
Has anyone removed this before and if so did you have these problems?
