Got it:thumbsup
The earlier e46s can be reset as follows
1.With Ignition Key in OFF position press and hold odometer reset down and turn ignition key to position 1 (Aux 1),
2. Keep button pressed for around 5 seconds and the words Oil change or Inspection plus RESET will display,
3. Release reset button then press reset button again until RESET begins to flash
4. Whilst reset is flashing, briefly press the reset button again and the display should read about 15250 which is the reset service interval distance.
5. After the reset distance is displayed, the caption "End SIA" appears in the display to confirm reset.
