right im going to do all this work my self insted of wiating for the garage to do it
1. change o ring on vacum pump to stop smoke
2. change throttle body to get rid of 2799 Abort DV-adaption because of enviroment
2786 Throttle-valve potentiometer 1
3. change throttle to air box pipe has it has been repaired with duck tape
will i need the codes deleted to stop eml light coming on or off
also what could be causing the tappet sound on the video has it seem to be coming from the inlet manifold
YouTube - e46 n42 bmw engine noise and smoke
When you change O-ring on vac pump, examine the unit because it could be that which is leaking (was on mine)
I had the same noise and smoke, both gone since i resealed the vac pump and cleaned out pcv hoses and oil seperator.
