i`ve had the car for nearly 2 weeks, and it not worked, it must have been reset just before i got it because it read only 12mls.
there are a few things wrong with the car, but i knew that when i got. the only elecy probs are trip reset and the outside temp sensor is missing, the rest is just body work.
Hi there, I have the same problem with the trip reset! I've got a 53 plate 320d and every other OBC function operates 100% ok, I can scroll through the functions using the left hand stalk. It too was working when I picked up the car as it was only showing 15 or so miles.
I've tried holding in the left hand reset switch for several seconds, held it in and turned ignition on but still no joy.
Has anyone out there had this fault fixed?
My colleague has a VW bora and he has used a VAG com lead to his laptop to check all his instrumentation, does BMW have an equivalent type of diagnostic, sorry DIY or specialist only as i can't afford dealer prices.
Thanks in advance, I'll update if i find anything else out.
