Hello folks. Looking for some advice and guidance please. My engine light has come on and the fault code is suggesting pre cat lambda fault (code 125 I think!?). It was previously intermittent but is now on constantly even after having the faults cleared etc.
Is there anything else that may cause this fault that I should check before splashing out on a new sensor? Sensor is an easy fix but still £60 ish quid so I'd rather check all possibilities.
I have got Carsoft so can post shots of the live readings if that will help at all?
Thanks in advance.:thumbsup
