1 - 20 of 26 Posts
Ok guys regarding my previous post about a rattly noise the noise sound more like a tappety noise between 1500-2000 rpm under load cant hear it when idel. i have checked oil level its ok.
the car has done 180,000 motorway miles with full bmw + specialist service history.
any idea what i can check or change the oil?
thanks and sorry for these different post
i,m not sure what oil the bmw specialist used as iv only had it 3 days. no noise remains same hot or cold its not loud but its there.
Strange if it's the tappets.
When they are serviced (or new) they have nothing in them so on startup they will be noisey, but once the oil gets through them they should be almost silent.
Then again one of them may have failed, or worn. The oil could be too thin and if the oil hasn't been changed often it may have worn one or more.
I would try dupping the oil that's in it and filling it with something new along with a new oil filter.
See what happens then.
There's lots of stuff on the net, IMO its personal preference but im running Vavoline 10w 60 VR1 oil in mine and it's smooth as.
ok thanks guys im going too remove the swirl flaps tomorrow will give it a oil change same time thanks
Just took note that it's a diesel - im not sure if the Vavoline stuff is good for them.
How clean is the oil thats in it ?
Discussion Starter #10
pretty dirty its had a inspection 2 in april but according too the service book oil was changed at 165,000. does inspection 2 involve oil change?
Discussion Starter #14
i checked my service where it states what is done at what inspection but it did'nt mention anything about changing the oil in that inspection oil air and fuel filter too be changed.
Last oil change was done at 161000 thats 19000 miles ago.
Better get it changed then :eek
I can't say i've ever come across diesel's turning the oil dirty before - with the exception of Saab 9-5's which are bad for that the oil should stay cleanish for a while.
10W-60 runs perfect in my E39 (petrol) it's REAL smooth now.
Discussion Starter #16
hey guys removed the swirl flaps changed a split hose power is back thank god.
Changed the oil used mobil 1 0w-40 noise has gone alot better very minimum if that
thanks for all your help and advice
As regards the oil i looked good and hard for my 2000 530d with 160000 miles on the clock and went for castrol 5w40 fully synth from halfords. £40 for 4 litres so you'll need 2 as it holds about 7 litres. Not cheap and i'm still in shock having never paid anything like it for oil before but i suppose its the right stuff and should be good for a while now. It does seem a little more tappety when cold than before but sounds great when warmed up, nothing excesive though.
Discussion Starter #18
i done mine yesterday bought 7 litres of mobil 1 0w-40 for £60 the tappety noise is completely gone i dont know why owners leave such long gaps between oil changes.
although bmw say 15000 miles between oil changes I Would do it every 8000 for the engines sake use quality oil and engine will last years.Oil should have been changed on inspection 2 along with plugs filters and a damn good check over.
1 - 20 of 26 Posts
