MY APOLOGIES I INITIALLY POSTED THIS IN THE WRONG SECTION
Ok, help me out here - where's the oil filter on my 530d? I've drained the oil, cleaned an absolutely filthy EGR valve, changed the air filter and then went to change the oil filter.
The only likely possibility I have found is just behind the power steering reservoir on the right hand side of the engine bay? It is kind of domed and has a 34mm+ hexagonal black plastic nut on top? I've stupidly tried releasing this nut with my plumbers pliers and it has cracked shattered!
Is this the casing for the oil canister?
I'm feeling very stupid for not being able to spot an oil filter........
Thanks in advance for any direction,
Ross
Ross
