Hi,
Can anyone help have you had a similar problem?
my e39 shakes the steering wheel under very light braking at 70, slightly heavier braking is perfect, dosent happen below 60 mph. I have new genuine bmw disc's and pads, discs re-checked they are dead true both sides and on the face the wheels bolt to. I have checked and re-ballanced the wheels twice, we have found no tyre faults the wheels are true, the wheel bearings are fine and the steering has no free play via the track rods back to the steering wheel. Standard bmw factory fit 16" alloy wheels.
Drives a treat handles well, have had car 2 years and never hit anything with the wheels.. this has just crept up on me. 92,000 miles on clock.
Was wondering if the rack had a damper or if bushes are known to wear which may cause the problem.
We did find the inner brake pads are marked right and left were fitted incorrectly and put them to the correct sides but no change? anyone know why they are handed?
have swopped rear wheels to front to eliminate, no change.
sorry it's a long post, but I have tried most obvious things first.
