1 - 9 of 9 Posts
Hello
could someone tell me where the oil filter is located on the 330d e 46.
is this a easy job to change the oil and filter , could someone please explain the process or send a link
cheers
BFuk Legend
IIRC its on the passenger side of the engine just behind the power steering fluid reservior. Its a black plastic cap with i think a 36mm hex on the top. :thumbsup
Ive not done one for a while...:frown
It is obvious when you do it. Just unscrew it and take the filter out from inside. Replace the O ring seals and put the new filter in. Only do it up till it stops. You don't want to screw the filter housing down too tightly because it is only plastic.
Also have a rag handy. When you take the filter out, it will drip oil so hold a rag under it.
Done mine last week and like you, was looking for ages under engine for filter thinking WTF. Then I came up for a *** and staring right at me was the oil filter in the engine bay. Easy to do, but you can't avoid spilling oil when you take old filter out.
1 - 9 of 9 Posts
