Hi guys,
I've got a 2001 325ti, which I think the suspension bushes have finally gone on (although I'm not 100% (especially on rough surfaces), I know it will tramline because it has 18 inch wheels, but if you try and push on, it doesn't really instill much confidence (especially compared to the BMW Mini's that I had before).
The rear end had started to squeak as well - if you rock the car from side to side with or without the handbrake on. There is also a rattle coming from the drivers side when you go over a speed bump of pothole - you can only hear it though when the window is down. Not sure if this is linked to dody bushings or something worse....
There is also a 'dead' spot on the straight ahead position on the steering wheel - which feels loose, if you slightly from side to side, nothing happens until you turn it a bit further. Again, not sure if this is relaed to the bushings - I did have Hughes Brothers in Derby look at it and the said that it was just natural play (I'm not so convinced....so another specialist is looking at it tomorrow).
Any idea how much I may be looking at (best and worse case). I was wondering about maybe trying to source the parts myself to save some cash - its due an MOT and Service in April / May !!!
Aside from that, it seems to be fine (other than going through a bit of oil every now and then!).
Cheers for any help / tips you can offer (sorry for the essay!)
