Hi Guy's,
My Coupe ran into a few probs 2day and was wondering if anyone has ahad any similar issues.
basically, driving along, the abs, eml and traction control light's came on but drove ok. Switched the car off and back on and the lights went out.
This went on at leat once a day until about an hour ago where the lights came on but this time the engine check light came up and all and I was not able to rev the car up...........floored the pedal but got almost no power at all, managed to crawl home.
I plugged in my EOBD reader and it broght up 3 codes:
P1634 - Throttle Valve adaptation: spring test failed
P1501 - Idle speed control valve stuck closed
P0014 - B Cam position
I reset the codes, fired the car up, the engine checl light went out but the other 3 lights were still on and still no power when gas pedal was pressed.
I re-read the codes and got a pending code of:
P1643 again.
can anyone shed some light on this please? I am thinking that my throttle body is buggered as I have seen these fail but would like a second opinion.
Any help would be much appreciated.
Thanks.
P1643 again.
Thanks.
