e46 320td compact, Fuel Rail Pressure Signal
Hi I need some help bigtime.
I purchased one of these performance box's (Drake) from ebay, when i pluged it in it ran but not efficient or fast, so i adjusted it 1mm per minute, test drive, 1mm again test drive etc. the box seemed to be of no benifit.
I contacted the seller and he asked me to send him photos of the install, he confirmed that it was fitted correctly.
I disconnected it and put it back to normal it seemed to drive ok however a day later it started to be sluggish, jerky and the turbo was out of time and became intermittent, possible coincidence but the problem was apparent when the diesel light came on.
a friend at a local garage got the code reading 3f31 Fuel rail pressure signal, the code also translates to:
3F31 Rail pressure sensor : Short circuit to B- or Open circuit
P0192 Fuel Rail Pressure Sensor Circuit Low.
My friend suggeted i replace the rail sensor therefore i did this however the code remained and drove the same.
I have swapped over all the relays under the glove box, except the orange 1??
I also removed the negative off of the battery for an hour and did a 1 minute ignition hold then switched off an over to start, i still get the problem any ideas please? BMW is fully booked till the end of aug and at £175 for 2 hour looking at it isnt impressive.
Many thanks
Steve
