I get the long beep when engaging reverse but nothing then. I thought it was due to the towbar but after getting this removed its still the same.
I turned the ignition on and listened to all sensors and there were no clicks from any of them. Could this be a fuse problem maybe or not because i get the long beep when reverse is engaged?
I've looked under the car at the back but theres only enough of a gap to work with one. How easy is it to remove the bumper to check the connections?
Did you listen carefully to each sensor for the clicking while the car was in reverse with the ignition on?
If yes then you need to get the fault codes read for the PDC system, then post them up here :)
