Folks,
As above, wanted to remove this for some time as its rusting and wanted to clean and repaint. It seems the bracket itself is held on via the 2 bolts on the wing, 2 trox screws at the wing side and a torx on the engine side.
Having removed all these the bracket would appear to just slide away from the palstic fuel filter housing but no budge, am I missing something or is it just "welded" to it with the rust...
Obviously dont want to go bashing around near there as its delicate an full of fuel!!!
Ta
Discussion Starter #2
anyone? I can't be the only one who's attempted this, this bracket is rusty on every E46 I;ve seen
It does but it's not exploede enough to see how its attached...I thought maybe there was a lip that it slid down on but as I said I dont want to push too much.
Also the housing is plastic and the bracket metal so surprise if there wa that much holding if the bracked was rusted
