Sorry for new thread, but have searched around and couldn't find this specific issue - sorry if it's been covered before.
Basically I'm looking for some advice on this issue. From cold my car, a 2001 E46 320Ci, has no problems. It starts and runs fine.
However, after it's warmed, sometimes it starts fine, but much of the time it will either;
- Have low torque, and be reluctant to pull from low revs
- From idle, when I go to depress the throttle the first bit of movement causes the revs to dip and the car to try and stall. If I come off the throttle it sometimes chokes a bit and recovers. If I press the throttle quickly past the first cm or two of movement the car will pick up revs, I can release the clutch and pull away okay.
- When pulling up to a halt sometimes the engine will simply die when the clutch is taken out. I then need to restart, with associated restarting problems.
Any ideas of what would be the problem? The car had an oil service recently and the mechanic said there was a camshaft sensor showing up, but he reset the EMU and drove for a while, and the error never recurred.
Would appreciate any advice on what the problem is or how to narrow it down.
Many thanks
Many thanks
