thanks all for the replys...
sorry for not updating thread i have been away for over 4 weeks with work!!!
i pin pointed the rattle to my waterpump as its got alot worse so gonna change it tomorrow if weathers ok...
as for my lower intake manifold... my exhaust is blowing and it sounds like its coming from the lower manifold....
plus i ve got a oil leak from the oil filter housing.. i ve got the new rectangle gasket but do i need to drain all the oil out or will it be ok to remove the housing as all the oil will sit in the sump?
cheers all
Remember to bleed the cooling system correctly after fitting the water pump :thumbsup
As for oil filter housing, you won't need to drain the oil from the sump but you will need to remove the oil filter top unless you want oil everywhere
You should also obtain #4/#5 here
http://www.realoem.com/bmw/showparts.do?model=BL32&mospid=47610&btnr=11_1568&hg=11&fg=30 to help with the oil leak.
