Hi to all,
looking for help with my 318i coupe. Recently started to have a laboured idle speed for a few seconds then revs will flick up to around 2500rpm and then fluctuate like this whilst stood at idle. This i believe is hunting, the local garage had a quick look today and they suspected an air leak, which they checked with a flamable substance ???
They were not able to detect a leak and advised i take it for diagnostics at a BMW main dealer.
If there was a air leak, would the idle speed hunt all the time as mine seems to be an intermittant prob ?
The garage that a purchased the vehicle from also suspect an air leak and can carry out a test which fills the induction system with pressurised smoke and therefore makes a leak easier to detect. Would this be worth a try or are they barking up the wrong tree looking for a leak.
Many thanks for any suggestions.
Also was tested today with a scanner which did not pick up any engine management faults.
J.B.
J.B.
