I appreciate that this has already been posted several times, but some of the threads are a couple of years old and there is no update as to whether or not the problem was ever solved.
I only bought the car five days ago, full service history, seems to be authentic 66000 miles, despite car being over 9 years old (registered in 02, n42 engine).
Same problem as reported in other threads, driving along at around 30mph, nothing excessive, battery light comes on for a second, car loses power as if its going to stall, then continues as normal. Its done it four times so far. Took it to my garage, the best locally, reliable reputable independant (not BMW dedicated, but have full diagnostic equipment, they used to service my 525 without problem, they have contract with local police force etc), were kind enough to check quickly without charge as I only wanted a battery checkup, they tested quickly the computer, and said it was not the battery or alternator, but I'm sure they said it was the "drive generator" or something similar. The car is back into them in 2 days for an electrician to check properly.
I'm hoping it is something as simple as a sensor (or even a loose connection on the battery!). I'm not particularly mechanically minded, the last car I worked on was a ford escort about 15 years ago!!
There is a high pitched drone or whine, not too loud, but loud enough to be irritating when driving with foot on throttle, which goes when foot off throttle, hope that that is not connected to the problem above. If it was bearing it wouldn't stop when remove foot would it?
I'll keep this thread updated, as it seems to be a common problem.
Thanks, Mike
Thanks, Mike
