Hi guy's,
Just took othe Mrs' car for a spin and noticed that I was getting knocking noises when on full lock..left and right lock..........the knock seems to be comming from the pass side wheel.
The knocking is not present while normal driving....just on lock and especially when reversing.
Also noticed that........if you put the car on full lock and then drive a full circle......the steering locks up and you need to force it off lock.
The car has had new wishbones and bushes both sides............obviously will be looking into this properly 2moro but has anyone had any similar issues...................I've heard the rack on these is prone to failing in this way?
