Just an update, got the radio out today after much pulling and found IT DOES NOT PIVOT OUT .You have to put a screw driver in the hole above the volume control and turn it 90 degrees then PULL IT STRAIGHT, the only problem i had is the mupet who fitted the handsfree kit had brocken the release mech and glued it back together.
Anyway all done now and thanks for your help.
Lee
