Hi All,
My 2001 525d has a tempermental fuel gauge and i want it fixing. Now, i COULD swap the clocks, but i, guessing
i need clocks from a manual diesel, as it says diesel on the fuel gauge. Ive looked on Fleebay, and theres LOADS
of petrol ones, but no diesel ones (dunno if it makes a difference)
OR, i can send my clocks away to get repaired, but to who?? I dont want to be paying £2-300 pounds just for
a slightly dodgey fuel gauge.
Any ideas anyone?? Could i use a petrol cluster in my diesel??
What do you mean temparamental?It could be the fuel sender.If you do a binnacle test it will show if there is a problem with the clocks :thumbsup
Ok, cheers, ive got the "how to" printed off for that. My local indie (without fully checking the car) said it'll be the clocks. I too thought sender but he did insist its the clocks. I'll do the test a see what it displays. Is it best to wait till the tank is near empty???
Oh, and the gauge is ok for the top half of the tank, but then goes back up to 3/4,s for a bit, then back to half, then just below etc. Its not all over the place though, it stays steady once its decided where to read :D
