Hi all, after checking around the car today looking for obvious reasons why the temp guage is playing up i noticed the coolant level was very low (below the plastic spike sticking up.
Ive seen there is a procedure to refilling the system, is it the same on the diesel engine.
Could this be why the guage is playing up even though the car isnt over heating, in fact while the car was running both the rad hoses were hardly hot at all and very soft (no pressure) so im hoping its not the dreaded HG.
Cheers Lee
Any problems just ask :cool
