I have just bought another 330d,that to be honest needs a bit of TLC ,but I knew this before ,
What I can"t figure out is the headlight ,If you turn the sidelights on ( switch in 1st position ) then all ok ,then switch to the next position and the main beam comes on ok . If you then push the stalk forward to put on high beam ,they dont come on and the dash light doesnt come on either.
If you just flash the lights then they flash ok,so cant be the bulbs
HELP
HELP
