hello, i have a 330 ci on a 2000 reg which has a oil leak from the off side, top of the engine which drops onto the manifold and burns, i've tried seeing where its coming from with no luck and done a search on the net but only found 1 sensible answer which said it could be a crank case vent valve or a hose going to it leaking. just wondering if anybody has any ideas?
many thanks
Crankcase valve piping seems a good place to start. See HERE. You can also see if there are leaks around the vanos solenoid and the manifold adjuster unit.
Could also be cam cover gasket(valve cover gasket as some say), common after time, the rubber goes hard
