1 - 15 of 15 Posts
Hiya, have joined the forum for some much needed help, have an E46 328i Se Touring, and we came home from xmas holidays, only to to find the car has gone into limp mode, we took it to a garage , they couldnt fix it, got the rac man round and he read the fault codes, he said it was a throttle sensor, so he towed my poor car to a bmw specialist in Northampton, they told me to get a new throttle body!! I sourced a second had one, from a great bmw breakers, took it to the garage , now have waited all week for it to return, rang them, they now say it wasnt the throttle body (GRRRRRRRRRRRRRRRRR) and are scratching there heads.... Please somebody shed some light!!!!, i have recentlty been made redundant so funds are tight, but having already paid one garage to do some work(well no work) im going to get stuck with another huge bill , any advise would be greatly appreciated.mark:thumbsup
169 MDK final stage
shut off
DME internal test This fault indicates problem on pedal
sensor, throttle potentiometer or
throttle. A separately stored fault
code indicates problem.
171 P0601 System has been
shut down due to
safety controller
DME internal test Safety controller has shut down motor
throttle valve function due to not
plausible MDK input values.
172 P1542 Pedal sensor
potentiometer short
between two
potentiometer
paths
DME internal
check
5 volts for potentiometers are
switched on within a specific time
pattern.
173 P0120 Motor throttle valve
potentiometer
contact short
Rationality check Motor throttle valve potentiometer
I got them a second hand throttle body, but they still cant get it out of limp mode
god knows. they are suposed to be professionals lol, they told me it was the throttle body, see what tomorrow brings, i got made redundant just before xmas so can really afford to get it fixed or keep it, know any body whos in the market??? its frustrating because ive already paid out nearly 200 to the first garage then 145 for the 2nd hand throttle body, i love the car just bad timing!!!!!:frown
I'm not very mechanically minded but the second hand throttle body did it come with it's own potentiometer as that is what is showing to be faulty throwing up code 171 implausable value also have they checked the wiring for cracks as that could be causing the short.
Oh and welcome to bimmerforums hope your back on the road soon mate
hopefully they will have it sorted soon, the throttle body came with the potentiometer, but i saw it on a car running before they bmw breakers took it off, cant afford to get it fixed now as was on limited budget due to situation.
I had the same problem once on e46, it turned out to be the ECU (DME). That sorted the problem for me. It might be a good idea for you to borrow one from someone and check that and see if it hepls!!!!
Discussion Starter #11
The "bmw specialist" has rang and they dont know whats wrong with it now..... so im stuck, i have decided to part company with my beloved bmw..... know any body who is in the know?? i have advertised it for 1400 no offers on piston heads and see if any body wants it.. im gutted!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ideally it would need better BMW spec diagnostics (their kit is pulling BMW codes, just giving the OBD2 name also, so it's not a bad code reader)
With a higher grade, there should be outputs of what the car can see / understand from each potentiometer.
Have similar problems. I have cleaned the maf (mass air flow meter) and I am cleaning the idle control valve. Easy to do at no cost, just carb cleaner u never know might work figers crossed......
Hi did yo umanage to sort your throttle body problem ? i seem to have the same one !
Regards
Uno
1 - 15 of 15 Posts
