I have no power steering have topped up oil,any suggestions on problem.:confused
T tiger22007 · Registered Joined Jan 14, 2011 · 6 Posts Discussion Starter • #1 • Mar 14, 2011 I have no power steering have topped up oil,any suggestions on problem.:confused
Ferret · Banned Joined Nov 7, 2009 · 4,013 Posts #2 • Mar 14, 2011 You will probably need a new pump... And when you say you've topped up the oil, did you top it up because it was run low ?
Ronnie · Registered Joined Dec 7, 2007 · 20,393 Posts #3 • Mar 14, 2011 Is the belt still on the car? Any lights on the dash? If belt is still on then it could well be your PAS pump, common enough for failing, you'll need a new pump. :frown
