I've had my coupe for three months now and my last E46 saloon was in 2002 but I don't seem to remember having so much trouble actually getting underneath it. I know I'm not the slim limbo dancer I once was, but I can't even get one arm under the coupe to reach the sump drain plug.
I've checked a few old posts on here, and the fact that the only jacking points available are the same ones that you put the axle stands under doesn't help.
To carry out an oil change I needed to get the car level so I bought a set of (extra wide) ramps to put the front wheels on. The front of the car hit the ramp well before the wheel did so a set of lead up ramps were purchased. This worked fine and I could just reach the diff bracket with my DIY trolley jack to jack up the back for axle stands. Unfortunately, there was no room to move the jack handle. Also the thought occured to me that if I did manage to get the rear wheels of the ground the car would probably roll off the ramps.:jaw-dropping So other than buying a two post lift, whats the answer? Or is a crash diet the only way to own a lowered BMW?
