:banghead.
I love my e46 and i love working on it but this is driving me nuts now!, i've searched and searched the net and am now down to the possiblilty of pump failure... it was intermittant at first with the 2 (asc & abs) lighting up,. i also had a buzzing from the abs pump just before the lights come on (imminent pump failure?) now the lights are on permanantly, i initially replaced the drivers side rear sensor which made the lights go out for a 5 mile journey!, so i got pa soft and read the codes,. after hours of googling i established the codes i had pointed to the front left sensor signal or front sensor inlet valve?, so ive replaced this sensor as well,..... the lights are still on and i cant clear the errors,. and to add insult to injury the handbrake light is now intermittantly coming on as well!!., does anyone think the initial buzzing from the ABS pump means its failed,(inlet valve code?) when i changed the front left sensor i had same codes apart from one,. codes below from ABS in pa soft,.>
dec 20 hex 0014 0/00 (Prior to frnt new lft sensor = dec 18)
dec 33 hex 0021 255/ff
dec 17 hex 0011 0/00..
all these codes are for inlet valve errors (if my abs is teves version 2?) does that mean the abs pump/modulator is shot?
can anyone help with this? dont want to spend shedloads of cash getting it sorted if i can diy replacment pump/modulator..
thanks!
2000 323ci
in car PC with touchscreen
18" m5 alloys
thanks!
2000 323ci
18" m5 alloys
