hi i have a bmw 320d ive had for abit now it has 157k on clock has a reciept for headgasket and turbo 25k ago so im confused,sometimes it gets hot and when it does loses all power when i leave it for a minute or 2 its fine just to get it to a garage i have un done the bleed screw next to filler cap and its presure when i bleed system its fine for a few weeks also if sat on the spot with heater going it loses water from somewhere unsure where any help would be good cheers.
When you say losing water when the heater is on, have you checked the footwells of your car to see if it is damp there?
Have you checked the rad cap O rings? the seals may have gone bad, otherwise get a coolant pressure test and headgasket test to alleviate any fears, if all good then the cooling system needs bleeding correctly.
Firstly, make sure your not topping it up with water, you should use boiled then cooled water or DI water. It should be with antifreeze in it in a 50/50 mix even in summer (water+antifreeze=coolent). The antifreeze lowers the boiling point of the coolent so that your engine runs above 100 Deg/C without boiling off, otherwise you would be constantly topping it up like it was a steam train.
Top tip.
If you really want your cooling system to work better, for longer, the next time you change your coolent, use De-ionised water you can buy it from halfords for topping up batteries or the cheap way si to freeze and then thaw 5 ltrs ice from your fridge =) this will stop it creating limescale inside the engine and increases the life of the pump and thermostat.
