I have a 2000 318iSE with 140k on the clock. Around 120k the engine light came on. Sometimes driving on the motorway it disapears. Using Proscan the following error was found: Powertrain fuel Bank1. Can anyone help? I did read a while back that it may be a vacuum leak but I need some guidance. Cheers.
Getting the codes read with a BMW specific scanner will be better, it will give you more info and insight into the problem, quite often it will give you more codes as well(good and bad thing,lol)
What was the code number as it's a EOBD code, P----?
