Got a 2000 318 Coupe.
Replaced the rear back discs two weeks ago and done the pads last weekend, but they are not making proper contact on the discs, you can see half the discs is rusting up where no contact is being made. This is on both sides
Anyone got any ides why, they are single piston calipers? so there is no way to ajust them is there?
Did you fit the caliper retaining clips back? If so, then I'm wondering if you have fitted warped discs, or your pads are glazed.
when i replaced my rear discs and pads i had same problem only working on half the disc on each side but after time they were ok dont worry took about 2 1/2 months though my mate had same problem on the front disc too
