Hi guys
i have just joiined buying a bmw e46 318i w reg
i am having problems with the idling the management light has come on and car is not running as good as she should mpg is really pathic i would fill up 30 pounds worth of fuel would give me something like 130 miles
so i went to the garage spoke to a guy who claimes he is a bmw specialist however i did see lots of certificated from bmw that he had pinned up
anyhow i originally went to him asking to do the diagnostic check
he listened to the car and said well we will open her up and have a look sounds like a leak in the pipe
so i left the car with him and let him get on took a day n a half was kinda pissed off with that but oh well
anyway went back to pick car up he showed me the pipe which was at the back of the engine you can just about see it
he showed me the pipe and he was right it was worn and had holes in it
so he changed that and another valve that goes with it
however when starting the car the idling was goig crazy like up and down and reving at 1700 rpm
so he saidits the air mass sensor the maf will need replacing so i paid him for changing three pipes git charged me £160 for it which i think is a joke !
Anyway i paid him he supplied the parts but the car was still not running as she should
every so slight the idling would drop car would shake for a sec then back to normal but when driving the car its fine, just when it stand still
so i today changed the maf and man the car got so much power . It drives well however the mpg has gone even worse
as in i was driving around town it did about 30 miles and the needle dropped dramatically like it was noticable
any how the old maf i checked cleaned used carb cleaner and try again as maf sensors are like 200 quid
i still have to check the results if results are same will take the new one back to get refund.
I will open the intake manifold up tomorrow to see if there are any other leaks and also to check why the car running so rich
i might have to do the diagnostic check and get this sorted asap
if anyone else having this problem let me know i can guide best way forward
any way will let you know of outcome.
