Hello,
Was driving and noticed a drop in power, then the battery light came on, and pulled over. Popped the bonnet and the water pump casing was totally bust, and the belt was obviously loose etc.
The engine still runs, and I've got the car booked into the garage on Monday. How long, and how much hassle is it to change the water pump myself? It doesn't look too bad in terms of access.
Cheers,
Darren
Super Moderator
easy change and about 35 quid for a pump for yours..
GSF do decent metal inpeller pumps..
hi im in the middle of changing mine. seems really easy to replace. However there one bolt i cant loosen. so ive posted on here for any ideas o n how to loosen it. Bt yeah im not very mechanically minded yet i am attempting it :)
um ive only removed the belt obv. how ever as im having trouble with this one bolt. i may be taking out thge thermostate just to get a little more room to move
easy to fix it a little hard on six cylinders just bcoz of space but can be done in 1hour maybe a little more time but i have done few of them just make sure you get some antifreez
