Hi everyone specially Ronnie I would like to ask you if you would be so kind as to post a diagram of the abs wheel sensors and if possible an insight into changing or curing false readings causing the traction and abs lights to come on cutting out the pump, as I have said previously my lights are coming on within ? -3 miles of take off. when I had the codes read he said it was showing a sensor fault but he was of the opinion it was the pump so change that first, after listening to all your comments I am inclined to think the replies on the forum hold more water and probably cheaper by doing the sensors first the pump must be working until it cuts out as I can feel the pedal pulsing at low speeds which as the replies have said indicates sensor fault.Thanks Chris
