I've had the traction control light and the ABS light come on, the car seems to loose a bit of power, the radio volume dims a bit & the speedo stops working.
As for the cruise control not working - I've not tested this.
I've also had the same thing happen with the traction control light and the dynamic brake control light (the yellow exclamation mark) coming on.
This is sporadic.
Is this likely to be a faulty sensor or something major like the ABS unit?
Could the loss in power mean the brakes are being applied a bit by the ABS unit?
Will disconnecting the sensors cure the problem temporarily until I can get it in to be repaired?
This is sporadic.
