1 - 18 of 18 Posts
Hi all
I have no rejoined the Bmw world with a 1999 E46 328se in black. The car is very clean and tidy with 119000 on the clock.
I have had her a week and have noticed:
Intermittent hesitation / missfire which from reading the forums is most likely a coil I believe, could it be anything else such as the MAF? I am going back to the garage I got it from on Saturday to be plugged in. Will the code reader clear up this issue or are there other things i can do to confirm? If its the coils (or a coil) can I mix bosch and beru? So if mine are all the originals can I put a bosch in and start a slow upgrade?
Coolant use. I am getting through nearly an expansion tank full every 70 odd miles, the temp stays bang on and I can see no sign of leaks dripping down anywhere. There is no gunk anywhere and the oil level is constant. It has been raining which makes it hard to see but are there any other places I need to check? I have been trying to look at the base of the radiator, the sides of the expansion tank and under the water pump and cant really see anything!!
The water pump is quiet - but I want to change it out to be on the safe side!! Is the metal impeller one listed on GSF for £40 ok to use?
Many tanks!!
Andy
Discussion Starter #2
I managed to have a look just after the engine was running and finally found it... the water is dripping at a good rate (well fast, its not good!) from what appears to be the expansion tank.
My question is, is it worth the extra cash for this:
http://www.eurocarparts.com/ecp/c/BMW_3+Series_328_2.8_1999/p/car-parts/car-cooling-parts-and-car-heating/cooling/expansion-tank/?205110290&1&c9ec16d3f6c38459da77a03998c00c05556f9590&EXPT
Is it actually any different?!
Also could someone please tell me if the misfire will log a code even the though no warning lights come on?!
THanks
Andy
I would use a genuine BMW expansion tank. The aftermarket ones aren't that good and might not even last the warranty period.
If it's not had a new radiator yet, it will be due a new one. You should really change the water pump as well - a bit of a kick in the nuts after you've just bought it, but 150-200 quids worth of bits now will save you a lot more in the long run. Change the drive belt and also replace or regrease any rollers that sound a bit dry.
Use a Nissens/Behr rad as some of the cheaper ones drip coolant from the hose connectors.
Yep use a bm tank not much more irrc, mine went pop at 100k miles the day after i bought the car doh!. Cost me around £80 all in.
Good advice! The ECP basic one is 51 plus vat and from BMW it is 58 all in so I am picking that on Saturday before heading to the dealership. They are paying for the part but to speed up the repair I am collecting the part.
They are also looking at the misfire on the kit and the failed washer jet. So hopefully all will be well next week.
you say misfire?
Are you having trouble starting ever/stalling? could be camshaft sensor as pretty common.
These run on chains so no cam belt will need replacing.
If your running a bit "skint" pop down breakers replacement parts are peanuts if not a BMW specialist and while offer no guarantee have always helped me out in a tough spot!
use realoem.com to find codes and parts for your car, then search that part on their site and see what other cars used it a nice easy way to open your breaker yard search from a specific model to a broad range..
Heck some stuff in breakers are brand new, just because your car has new spark plugs doesn't mean you won't smash it up tomorrow!
For the plugs, these were stock:
08 Spark plug, High Power BOSCH FGR7DQP 6 12120141871 ENDED
08 Spark plug, High Power 6 12120037607
08 Spark plug, High Power NGK BKR6EQUP 6 12129071003 ENDED
Part codes are the 121 numbers,..
example the replacement spark plug was found on all these models:
E31: Details on E31
E31 850Ci Coupé, Europe
E31 840Ci Coupé, Europe
E31 840i Coupé, Europe
E32: Details on E32
E32 750i Saloon, Europe
E32 750iL Saloon, Europe
E32 730i Saloon, Europe
E32 730iL Saloon, Europe
E32 740i Saloon, Europe
E32 740iL Saloon, Europe
E34: Details on E34
E34 518i Touring, Europe
E34 518i Saloon, Europe
E34 518g Touring, Europe
E34 530i Saloon, Europe
E34 530i Touring, Europe
E34 540i Touring, Europe
E34 540i Saloon, Europe
E34 520i Saloon, Europe
E34 520i Touring, Europe
E34 525i Touring, Europe
E34 525i Saloon, Europe
E34 525ix Touring, Europe
E34 525ix Saloon, Europe
E36: Details on E36
E36 316i Saloon, Europe
E36 318i Saloon, Europe
E36 320i Saloon, Europe
E36 320i Touring, Europe
E36 320i Coupé, Europe
E36 320i Convertible, Europe
E36 323i Touring, Europe
E36 323i Coupé, Europe
E36 323i Convertible, Europe
E36 323i Saloon, Europe
E36 323ti Compact, Europe
E36 325i Coupé, Europe
E36 325i Convertible, Europe
E36 325i Saloon, Europe
E36 328i Saloon, Europe
E36 328i Coupé, Europe
E36 328i Convertible, Europe
E36 328i Touring, Europe
E36 316g Compact, Europe
E36 316i Touring, Europe
E36 316i Coupé, Europe
E36 316i 1.6 Compact, Europe
E36 318i Convertible, Europe
E36 318i Touring, Europe
E36 318is Coupé, Europe
E36 318is Saloon, Europe
E36 318ti Compact, Europe
E36 316i 1.9 Compact, Europe
E38: Details on E38
E38 750i Saloon, Europe
E38 750iL Saloon, Europe
E38 750iLP Saloon, Europe
E38 750iLS Saloon, Europe
E38 L7 Saloon, Europe
E38 730i Saloon, Europe
E38 730iL Saloon, Europe
E38 735i Saloon, Europe
E38 735iL Saloon, Europe
E38 740i Saloon, Europe
E38 740iL Saloon, Europe
E38 740iLP Saloon, Europe
E38 728i Saloon, Europe
E38 728iL Saloon, Europe
E39: Details on E39
E39 520i Saloon, Europe
E39 520i Touring, Europe
E39 523i Saloon, Europe
E39 523i Touring, Europe
E39 528i Saloon, Europe
E39 528i Touring, Europe
E39 535i Saloon, Europe
E39 540i Touring, Europe
E39 540i Saloon, Europe
E39 540iP Saloon, Europe
E39 525i Saloon, Europe
E39 525i Touring, Europe
E39 530i Saloon, Europe
E39 530i Touring, Europe
E46: Details on E46
E46 320Ci Coupé, Europe
E46 320i Touring, Europe
E46 320i Saloon, Europe
E46 323Ci Coupé, Europe
E46 323Ci Convertible, Europe
E46 323i Saloon, Europe
E46 328Ci Coupé, Europe
E46 328i Saloon, Europe
E46 328i Touring, Europe
E46 316Ci Coupé, Europe
E46 316i 1.6 Saloon, Europe
E46 316i 1.9 Saloon, Europe
E46 318Ci Coupé, Europe
E46 318i Saloon, Europe
E46 318i Touring, Europe
E46 320Ci Convertible, Europe
E46 325Ci Coupé, Europe
E46 325Ci Convertible, Europe
E46 325i Saloon, Europe
E46 325i Touring, Europe
E46 325ti Compact, Europe
E46 325xi Saloon, Europe
E46 325xi Touring, Europe
E46 330Ci Coupé, Europe
E46 330Ci Convertible, Europe
E46 330i Saloon, Europe
E46 330i Touring, Europe
E46 330xi Saloon, Europe
E46 330xi Touring, Europe
E46 316i Saloon, Europe
E46 316i Touring, Europe
E46 316ti Compact, Europe
E46 318Ci Convertible, Europe
E46 318ti Compact, Europe
E53: Details on E53
E53 X5 3.0i SUV, Europe
E53 X5 4.4i SUV, Europe
E53 X5 4.6is SUV, Europe
E60: Details on E60
E60 520i Saloon, Europe
E60 525i Saloon, Europe
E60 530i Saloon, Europe
E60 545i Saloon, Europe
E61: Details on E61
E61 525i Touring, Europe
E61 545i Touring, Europe
E63: Details on E63
E63 645Ci Coupé, Europe
E64: Details on E64
E64 645Ci Convertible, Europe
E65: Details on E65
E65 730i Saloon, Europe
E65 735i Saloon, Europe
E65 745i Saloon, Europe
E65 760i Saloon, Europe
E66: Details on E66
E66 730Li Saloon, Europe
E66 735Li Saloon, Europe
E66 745Li Saloon, Europe
E66 760Li Saloon, Europe
E67: Details on E67
E67 745LiS Saloon, Europe
E67 760LiS Saloon, Europe
E83: Details on E83
E83 X3 2.5i SUV, Europe
E83 X3 3.0i SUV, Europe
E85: Details on E85
E85 Z4 2.2i Roadster, Europe
E85 Z4 2.5i Roadster, Europe
E85 Z4 3.0i Roadster, Europe
Z3: Details on Z3
Z3 Z3 2.0 Roadster, Europe
Z3 Z3 2.8 Roadster, Europe
Z3 Z3 2.8 Coupé, Europe
Z3 Z3 1.8 Roadster, Europe
Z3 Z3 1.9 Roadster, Europe
Z3 Z3 2.2i Roadster, Europe
Z3 Z3 3.0i Roadster, Europe
Z3 Z3 3.0i Coupé, Europe
It is an intermittent misfire, most of the time it is smooth as silk. An yes I have stalled twice when going to reverse when suddenly the car has decided that more revs are needed and also once when pulling out of a petrol station.
My assumption was a coil pack on the way. Would the ECU log the issue correctly so that if it is a coil or sensor it will show the difference? No warning lights are coming on.
Many thanks for the useful info! Funds are tight at the moment as I haven't sold my other toys yet :s
Idle control valve, a vacuum leak - or both. Read the codes first, but if either of these things are knackered, they won't show codes.
Have a look roundd the engine bay for air leaks. the intake trunk is prone to breaking and theres a pipe on the top of the inlet manifold that also splits, sucking in air. this confuses the readings and it goes all silly. :)
If it did it when it was warm and not cold, then i'd say cam sensor.
Discussion Starter #10
Well the expansion tank was switched out fine, the washer motor had jammed up so a new one is on the way.
It was an indy garage with a SnapOn diagnostic kit. The car has not put on a warning light and his kit was unable to find any fault codes on the car.
THe car drove home like a dream...
However the night before it was a pig to drive as it would try to stall when pulling away - more revs got it moving and was not smooth.
It idles ok so does that rule out an air leak. I couldnt hear any thing hissing with the bonnet up.
Would a dodge cam position sensor flash a code? Really want to get it all running properly!!
Yes it would.
A vacuum leak is still your best bet OR the idle control valve. When the car is idling, without load on the engine, it can be really hard to detect. Even spraying carb cleaner on the pipework so see if the engine note changes won't always find leaks & splits.
I did a guide a while back on finding vacuum leaks, it's in the "how to" section.
HTH
Discussion Starter #13
looked up CDV and that explains the occasional annoyance I experience so it will come out.
As to the other issue I drove home tonight and the car was perfect. I then stopped for 4 minutes to run into a shop and when I came out the car was hesitant again and trying to manoverue up my lane into a space it just kept stalling.
Still no error codes coming up.
A MAF clean is on the cards next I think!
Discussion Starter #14
I am trying to work out what MAF should fit my car, as from reading the forums I see its a Bosch part.
Does anyone know of a website that will reliably take a BMW part number and give me the Bosch one?!
Many thanks
Discussion Starter #15
Update
I don't know if its just me BUT the problem seems to occur when I restart the engine and it is already hot.
Does this help in working out which bit has failed??!
Any advice would be great!
Crankshaft position sensor!!! It's the only thing that tells the ECU how quickly the engine is spinning, and if it's shot, the ECU hasn't got a clue where the engine timing is/should be, so it will misfire/run rough (if at all). They're bad when hot, fine when cold.
Link to part: http://www.realoem.com/bmw/showparts.do?model=AN51&mospid=47641&btnr=11_2167&hg=11&fg=10&hl=32
HTH
1 - 18 of 18 Posts
