1 - 8 of 8 Posts
Discussion Starter #1 (Edited by Moderator)
First of all sorry if this is posted in the wrong place as i am new to the site! i finally got my dream of owning my first BMW just before Christmas :). i brought a 328i SE 4 door on a 99. Only to 4 days later have to unavoidably drive through a hole in the road caused by the recent terrible weather. the hole in question was 47" long 16" wide and 5" deep. I was travelling at 40mph and the force of this caused the N/s front, rear, and roof curtain air bags to deploy:frown. there was no structural damage to the car but i never doubted it's build that's why i chose BMW. I have found an airbag kit on eBay and blow off cable for the battery. I'm confidant i can fit all these parts but it's the ecu info that i need. Does the airbag ecu need pairing to the engine ecu? somebody told me that i would have to buy the engine ecu also! any advice would be gratefully accepted as i want to get her back to the perfect state that she deserves.
Hmmm not sure?
I've disconnected and reconnected the drivers door one when I fixed the window regulator, had the battery disconnected during caused no problem.
From what I remember there's only two wires to it which suggests it's triggered by a simple current, therefore simply plug and play like mentioned and no coding needed ?
HTH
cheers m8 some told me today that i can plug new ones in and will need ecu resetting. But they are not bimmer knowledgeable the claim to the council is already in!. to make matters worse i had just picked the missus up from the hospital from having a major op and the seat belt restraint busted the stitches open in her stomach.! she ok now though.
You should be okay to replace the expended parts (diconnector and airbag), then you need the airbag ECU reset. INPA, autologic etc
1 - 8 of 8 Posts
