I have the above car and i ran an error check with a friends scanner tool using Pasoft 1.3.6
this is what i have:
DME
Error Code (Dec) - 45
Error Code (HEX) - 002D
Parametre hex/dec - 104 / 68
ABS
Error Code (Dec) - 49
Error Code (HEX) - 0031
Parametre hex/dec - 0 / 00
Error Code (Dec) - 65
Error Code (HEX) - 0041
Error Code (Dec) - 50
Error Code (HEX) - 0032
SRS
Error Code (Dec) - 1
Error Code (HEX) - 0001
Parametre hex/dec - 66 / 42
any help on pinpointing these would be great. have an engine warning light on atm.
:sarcastic
DME
http://www.endtuning.com/bmwcodes.html#MS41
Multifunction steering wheel - Port
ABS
49 - ABS1- Rear right wheel sensor or Outlet Valve - Front right
ABS2- Power Supply Solenoids
65 -ABS1 Wheel sensor Rear right or Wheel speed sensor PSU
ABS2 - ASC Computer Fault
50 ABS1 - Wheel sensor -Rear Left or Outlet valve Front Left
ABS2 - Throttle Valve Mechanical Fault
SRS
SRS-1 Control Unit Internal Fault
On balance, I would guess you have the ABS1 system, as all the codes are in the same field, and this is most likely from wheelspinning in the snow (unless you happen to wheelspin on other occasions ;) )
The ECU fault is signals from the multifunction wheel, also SRS which is the main airbag module is reporting a general fault. Error code 1 on any module isn't good, they usually hold that number for big problems, so clear it if you can, especially if you have made any changes to the steering wheel or SRS module.
