Just after xmas I was driving and squirted the washers and they went weak and then stopped. I checked and the water tank was near full.
Since then I have take the pump off cleaned it off, cleaned the tank ( was not that dirty). Still no joy. :mad
I disconnected the pipe from the washer nozzle and pulled the washer stalk and water came out the hose (so the hoses are not blocked or frozen). I have taken a nozzle off and poked it with various pins and other small strands of metal. Still no joy. :mad
I cant seem to blow through the nozzles so there is definately someting in the nozzle causing a problem, I would just replace all the nozzles with new but I am a bit surprised that all four nozzles have stopped working at the same time (bonnet and headlights). The nozzles are heated would this have caused a problem (I have check all associated fuses and all are fine)
Can anyone help??? Please.
