Hi All,
I have just bought a P.A.Soft scanner for my 328i (1999), complete with big round plug thing (which mine has). Worked first time, came up with lots of errors...
Errors details (dec)
DME -> 216/180
EWS -> 3/10 15/63 0/7 1/1
ABS -> 148/1 118/1 65/247
SRS -> 10/192
IKE -> 247/132 135/129 190/136 246/132 248/132
LCM -> 31/2 32/2
ZKE -> 61/7 48/1 56/2
Find units end
:eek ... and then cleared the majority of them...
DME -> 216/180
Errors after clear:
no errors
Errors after clear:
no errors
ABS -> 148/1 118/1 65/246
Errors after clear:
148/0 118/0 65/0
SRS -> 10/192
Errors after clear:
no errors
Errors after clear:
no errors
LCM -> 31/2 32/2
Errors after clear:
no errors
Errors after clear:
no errors
Clear errors end
:thumbsup
Leaving me with some ABS errors, which I expected, as the lights been on from time to time ever since the weather got proper cold, so I'm expecting this problem to come back sometime soon!
The Airbag light has been on for months, and this has finally gone out... which is nice... I have an MOT coming up very soon!
I haven't driven it yet since, so some of these errors might come back.
Now I expected to have to do some research to find out what these numbers mean, but so far have had no luck. I've found all sorts of lists for OBD-2 error codes, but none match the numbers I'm seeing here.
Does anyone here know of a list/link/website this covers these error codes, and explains their meanings? :confused
Any information gratefully received
You'll need to edit your title to add year/model details.
Click edit, then go advanced.
I have the important codes here
http://endtuning.com/bmwcodes.html
I have got lists of the others but have yet to finish tidying them up and publishing them
Thanks, TheEnd! That definitely helps out, and I think covers some of the ABS faults I still have. My Airbag warning light did not stay off for long (back on this morning!), and I cant find that in your lists. If you have something to cover that, or could just email me what ever you have for me to traw through, it would be very much appreciated. :thumbsup
DME -> 216/180
Lambda sensor - frequency 180
No data as yet - usually minor keys not recognised
148 Can Error - Freq 1
118 Interferance speed signals- freq 1
65 Wheel sensor rear right - freq 247
SRS -> 10/192
10 Driver's side pretensioner - frq 192
247 - No CAN id frq-132
135 - K Bus freq 129
190- Light module eeprom error freq 136
246- No CAN id freq132
248- No CAN id frequency 132
check the plugs on the back!
LCM -> 31/2 32/2
61- Boot lid locking mechanism - freq 7
48- K Bus freq 1
56- Windscreen washer pump
Find units end
I'll have a look if I can find the LCM codes.
Wow, that's brilliant, thanks very much :)
I have done another check now after a 500 mile weekend, and the only faults that have reoccurred are the DME, SRS and ABS faults.
DME -> 216/180
ABS -> 148/0 118/0 65/0
SRS -> 10/192
However the ABS lights have behaved themselves, so I'm hopeful they'll stay off long enough for the MOT! The fault on those definitely seems to be connected to the real frosty weather we've had.
Thanks again for the fault code lookup, I'll start checking through the significant bits of car :)
Back with SRS Error codes again!
It MOT time again, and no Airbag warning lights are allowed anymore!
I've just replaced my Drivers Pretensioner as per previous post (I know, took a while getting around to that!), and now I have a different fault code!!?
SRS -> 10 \ 66 (Both in Decimal)
So, here we go again... Does anybody have a definitive list that covers all these error codes?? Or can point me in the right direction for this particular code?
Thanks!
Paul.
(E46 328iSE 1999)
