My car shudders/vibrates under load, especially going uphill or when I floor the pedal. Vibration comes from the middle of the car or from the rear left wheel area. Am getting the driveshaft centre bearing replaced but a friend reckons the driveshaft velocity joint is the culprit. If this is the case is this an easy fix and if I get an indy to do it how much would I be looking at? ££££££
Ronnie, I changed the doughnut around 3 months ago. Apparently you should pre-load the driveshaft after this but didn't know this at the time. Could not pre-loading it be the culprit?
