Hi all. I am hoping someone can help me sort out an airbag fault on my E46.
I aquired the car with the fault. I was advised at the time it came on when the car was valeted, but checking the past MOT reports I think this is not the case. After having the car looked at too, it would appear that the seats have been replaced too with the Half Alacantra ones from the facelift model (this is what I have been told anyway).
Anyhow, there are no fault codes on the drivers side, this is all OK. I am also aware that there is a bypass kit for the sensor to detect someones arse in the passenger seat, but with the number of faults I have on my passenger side I don't know if this would be money wasted tbh.
Here are the fault codes:
I have attached some photos I took when I removed the seat to inspect the connections and to get photos of the part numbers.
Also:
I ended up taking out the base of the rear seats only to find a grey plug on the end of a piece of wire that leads into the back of the car somewhere (I didn't investigate further). Does anyone know what this is? The last three pictures show this plug. And yes, that is a bit of blood on one of the labels. I cut my hand on a screwdriver taking off the cables :/
Code:
33 - sensor sidebag left communication error or broken cable
[color=blue] Fixed by disconnecting the airbag in the door card, blowing the connectors and reconnecting. [/color]
24 - seat occupied recognition (communication error - break in seat mat)
[color=blue] Fixed by installing a bypass unit from Ebay at a cost of ÂŁ8.[/color]
8 - ignition circuit 4 -> side airbag left (Remain over limiting value)
[color=blue]Fixed as per fault code 33.[/color]
6 - ignition circuit 2 -> passenger belt stronger (Remain over limiting value)
Also:
