hi all,
we have a bmw e46 318i 1900cc 1999, all started with the car not responding as quick as it should when accelerating and rough tick over , so we changed the spark plugs, then we noticed a noise under the bonnet and changed the crankcase valve, now this is where the problem began, after changing it, took on test drive (as noise had gone) but the tick over n acceleration still the same . then the eml came on codes lead to evap small leak 61, vanos output stage cyl~5-8 a6, asc signal plausibility 8d, reset eml, have checked the pipes for leaks around the ccv, and can not find anything, but im sure its something that happened while changing the ccv can anyone throw any light on this for me please
