Hello lads, I know rear brake pipes have been mentioned before, but not sure if they covered convertibles.
I've got the car on axle stands and have undone the three tank straps, but it looks as if you have to be some sort of contortionist, to get anywhere near the feed to the offside. It looks as if it would be easier to drop the exhaust and prop shaft to allow the tank to drop enough to at least get your hands in to manouver and position the new pipes to avoid any rubbing.
Am I causing myself alot of work, or is there something else I should be doing ?
Any advice would be very welcome. Cheers in advance. Tony.:timebomb
